cannot console to CAT4006
Sep 24th, 2009
I can SSH but I cannot console in.The following is the config.How can I console in with credentials that I use for SSH
line con 0
exec-timeout 20 0
logging synchronous
login authentication aaaconsole
stopbits 1
aaa authentication login aaaconsole none
tprendergast Thu, 09/24/2009 - 10:54
  • Silver, 250 points or more
You probably want
aaa authentication login aaaconsole local
I assume you are using local or aaa for the ssh credentials?
CCDECCDE9 Thu, 09/24/2009 - 11:02
aaa authentication login default group radius line enable
