Delay on external application from LAN.
Sep 24th, 2009
I'm having a big delay with an external application.
When I do this connection:
PC - Sw2900 - Core5500 - Router - WAN
The application takes 2 minutes for making any request.
When I do next connection:
PC - Core5500 - WAN.
The application takes 10 seconds for making any request.
I changed the fiber connection, Ethernet port, it's working with full duplex, I sent a lot of traffic from the Sw2900, I didn't any error, I disabled the local firewall of PC.
Do you know If I can check something else?.
Do you know If I can do anything on the Sw2900?.
Thank you.
Lucien Avramov Thu, 09/24/2009 - 17:55
What kind of application are you using?
What ports does it use?
In your next connection there is no router anymore in the picture after the core 5500, I presume this is a mistake.
The switch 2900 is probably just doing L2 switching.
What does your IP addressing looks like?
Also can you share your 2900 show run output?
luisveraza Fri, 09/25/2009 - 05:23
It's a costs application.
It was an error:
PC - Sw2900 - Core5500 - Router - WAN.
The sw 2900 is only L2 switching.
It's one network with subnetmask of 24.
Sure, I addedd here the sh run command.
What do you mean with output ?.
