CCM7 and CDR billing server
Sep 24th, 2009
The cdr records show up on my billing server ever couple of minutes.I read you can tweak this to 1440 minutes. Is it possible to get a flat(1) monthly cdr record from callmanager to a billing server? Rather than getting hundreds if not thousands of files a month? I am looking for 1 record for the full month sent to my billing server. It does not appear the scheduler can handle this?
hadbou Wed, 09/30/2009 - 11:40
To resolve this problem, you must edit the trigger (using a text editor) to point to the current name of the database.
walker-ryan Wed, 09/30/2009 - 11:42
Thanks for the reply but I am not sure I am following your response
Christoph Hable Thu, 10/01/2009 - 05:09
I have the same problem. i want to push CDR records to an external server every sunday - i've configured the scheduler in the CDR management configuration but i get the data continiously transferred.
Can anyone explain howto manage this?
walker-ryan Thu, 10/01/2009 - 06:35
Hi Christoph,
I was told this cannot be done, the scheduler is not able to send to a external billing server the best you can do is 1 file every 24hrs
