09-24-2009 02:51 PM - edited 03-04-2019 06:09 AM
I have two 2821 routers running OSPFv3 with Address Family IPv4. These two routers are connected via static routes through a WAN therefore OSPF router on one side of the WAN is not running or advertising to the other OSPF router on the other side of the WAN.
Would you please give some advice on how to configure tunneling for OSPF instead of using static routes?
Here're parts of router running-config files.
hostname Router4
policy-map FQ
class class-default
fair-queue
interface GigabitEthernet0/0
Description external WAN
ip address 192.x.x.104 255.255.255.0
duplex auto
speed auto
ipv6 enable
ospfv3 instance 64 network manet
ospfv3 1 area 0 address-family ipv4 instance 64
service-policy output FQ
interface GigabitEthernet0/1
Description internal LAN
ip address 192.x.2.40 255.255.255.0
duplex auto
speed auto
ipv6 enable
router ospfv3 1
router-id 4.4.4.4
log-adjacency-changes
address-family ipv4
timers spf 1 2
router-id 4.4.4.4
exit-address-family
ip forward-protocol nd
ip route 142.x.x.0 255.255.255.0 192.x.x.172
ip route 192.x.4.0 255.255.255.0 192.x.x.172
hostname Router5
policy-map FQ
class class-default
fair-queue
ip address 142.x.x.105 255.255.255.0
duplex auto
speed auto
ipv6 enable
ip address 192.x.4.40 255.255.255.0
duplex auto
speed auto
ipv6 enable
router ospfv3 1
router-id 5.5.5.5
address-family ipv4
timers spf 1 2
router-id 5.5.5.5
exit-address-family
ip route 192.x.x.0 255.255.255.0 142.x.x.172
ip route 192.x.2.0 255.255.255.0 142.x.x.172
Thanks.
09-24-2009 06:20 PM
HI,
You can configure a GRE tunnel between both routers and run OSPF in it instead of the WAN interface.
Never try with OSPFv3 and IPv4 AF so.
Laurent.
09-24-2009 07:10 PM
Here is how to configure it:
09-28-2009 07:21 AM
I could not get to the document from the URL you provided:
Would you please check. Thanks.
09-25-2009 04:12 AM
Hello Hugh,
also for me it is the first time I see this address-family IPv4 with OSPFv3.
I don't know if it is only a typing error but I see two different ipv4 addresses on WAN interfaces
R4: 192.x.x.104/24
R5: 142.x.x.105/24
are these supposed to be connected directly between them?
if so they should share a common ipv4 subnet.
But I see here
http://www.cisco.com/web/strategy/docs/gov/OSPFv3_aag.pdf
that this condition with different IPv4 subnets should be supported if the two devices are directly connected because communication use IPv6 link local for LSA exchange.
Or if devices in the middle are able to send IPV4 family related LSA downstream.
However, it's not clear how the forwarding of IPv4 packets over the IPv6 only path can work: it requires some form of tunneling of IPv4 into IPv6 packets. (the opposite of what is done in most cases today where it is IPv6 tunneled into IPv4)
Hope to help
Giuseppe
09-28-2009 09:26 AM
Hello all,
Thanks for all the advices. After set up tunneling for ospf and removed all the static routes, ospf routers were able to advertise to the other and I can ping every node on ospf networks. However, I have not tested with IPv6 addresses. Not sure if ospf tunneling will forwards IPv6. Here're changes to the config files:
hostname Router4
policy-map FQ
class class-default
fair-queue
interface Tunnel0
ip address 10.1.1.1 255.255.255.0
tunnel source GigabitEthernet0/0
tunnel destination 142.x.x.105
duplex auto
speed auto
ipv6 enable
duplex auto
speed auto
ipv6 enable
router ospfv3 1
router-id 4.4.4.4
address-family ipv4
timers spf 1 2
router-id 4.4.4.4
exit-address-family
hostname Router5
policy-map FQ
class class-default
fair-queue
interface Tunnel0
ip address 10.1.1.2 255.255.255.0
duplex auto
speed auto
ipv6 enable
duplex auto
speed auto
ipv6 enable
router ospfv3 1
router-id 5.5.5.5
address-family ipv4
timers spf 1 2
router-id 5.5.5.5
exit-address-family
Thanks.
