09-24-2009 05:12 PM - edited 03-18-2019 11:44 PM
Hello All,
I'am running CUCM 7.0 and I have a 7936 conference bridge but none of the menu buttons are functioning, the only one that works is Join. I'am primarily trying to get the meetme to work but when I hit the button it doesn't do anything. Has anyone run into this issue? Thanks
Solved! Go to Solution.
09-25-2009 11:08 AM
Has the meetme button ever worked? I have found that on the 7936 conference phone, the meetme button will not function unless you are 'off hook'. When you have dial tone, go to the meetme option and it should work.
09-25-2009 11:08 AM
09-25-2009 11:42 AM
Thanks that was it!!!! Unbelievable!!
