Tacacs or Enable Secret Not Working
Answered Question
Sep 24th, 2009
hi experts,
i have a 2821 router set up for tacacs for default login and configured enable secret. the funny thing is that when i telnet into this device and login using my tacacs credentials, it directly prompts me to privilege mode (router#). my other device is prompting me to user mode (router>). can anyone help me how to configure this router to user mode and ask for the enable secret.
Correct Answer by Collin Clark about 7 years 3 months ago
Check your VTY lines. Look for a statement like-
privilege level 15
If it's there, remove it. If it's not there, the privilege is probably in ACS.
Overall Rating: 5 (2 ratings)
Correct Answer
Collin Clark Fri, 09/25/2009 - 05:19
privilege level 15
johnlloyd_13 Sat, 09/26/2009 - 21:17
hi collin,
thanks! you were right. there was this config under line vty. i've removed it and prompted me to user mode.
Rolf Fischer Fri, 09/25/2009 - 08:52
Your tacacs-server can provide 3 things (AAA):
A - Authentication (who are you?)
A - Authorization (here we can define what method/database to use for the login-privilege for a particular group - if we want that!)
A - Accounting (who did what?)
The configured aaa-groups can be assigned to line con 0, line vty ..., ...
router(config-line)#login authentication default
("default" is the name of the list configurerd with "aaa ...")
Maybe you can post the relavant part of your config (aaa...; line ...)
Jagdeep Gambhir Fri, 09/25/2009 - 09:09
Hi John,
You need to remove this command from the router,
aaa authorization exec default group tacacs
or
You can also remove the shell privilege 15 from ACS group setup.
~JG
Do rate helpful posts
Rolf Fischer Fri, 09/25/2009 - 10:26
Think I didn't explain very well...
I was thinking of something like that:
aaa new-model
aaa authentication login TELNET group tacacs+
line vty 0 4
login authentication TELNET
line vty 5 15
"TELNET" ist just the name of my list.
There is also a default list which uses the local database. I didn't define anything for authorization, so the local database (-> enable-password) is used.
