Multiple authentication methods on SSH access
Sep 24th, 2009
After the implementation of ACS, all the network switch authentication is under ACS with local as backup. Is that any solution to separate the authentication methods (Local & TACACS+) of SSH access to the switch (line vty 0 3 = TACACS+, line vty 4 = Local)? Same as router SSH reverse telnet, but "ip ssh port" is not supported on the switch.
Collin Clark Fri, 09/25/2009 - 05:57
  • Purple, 4500 points or more
You can configure lines 0-3 for TACACS
line vty 0 3
login authentication TACACSMethod
and vty line 4 for local
line vty 4
login authentication local
Jatin Katyal Fri, 09/25/2009 - 08:00
  • Cisco Employee,
!---This can be possible by configuring !---method list on the device.
tacacs-server host key
aaa authentication login list group tacacs+ local
line vty 0 3
login authentication list
line vty 4
List=name of the method list.
JK
laut Sun, 09/27/2009 - 17:27
I've tried this before, but the ssh connection should go through one by one. line vty 0 -> 1 -> 2 -> 3 -> 4. If no one make the ssh connection before, the connection should on line vty 0. How to make the ssh conenction to specific line vty for particular authentication method? As mentioned before, the router can provide the solution to assiocate the line vty to rotary with different ssh listening ports. As similar solution or other approach for the switch to provide the same kind of services.
Thanks.
TL
Collin Clark Mon, 09/28/2009 - 05:36
AFAIK there is no way to do it.
