pcomm over smart tunnel
Sep 24th, 2009
I wonder if anybody tried to run ibm pcomm application over smart tunnel to connect to the mainframe. It is telnet like software. I am trying to make it work but I think I am missing something. By the way I can RDP to Wintel on the same subnet. It works fine using port forwarding but to confusing for end users. Thank you in advance.
auraza Mon, 09/28/2009 - 10:32
Are you referencing the correct process in the Smart Tunnel list?
20vek Mon, 09/28/2009 - 11:43
Hi. Thanks for the reply. It is all fixed now.
