High Latency and Frequent Disconnection on Wireless Link Pls help.
Sep 24th, 2009
Dear All,
I am facing a problem as shown below.
The NW Rough Di. is shown in attached.
All the Aps Wireless connectivity from AP connected using UTP has high latency ( > 500 ms ) and frequent discoonection. When I remove the global Network and than check the ping of all Aps which are connected using wireless link are working properly without disconnection.
So what could be the problem ?
Pls guide me urgently.
my Contact No is : +91 9276863595
Deepesh P.
nitin.madan Sat, 09/26/2009 - 23:43
Is there any seperate vlan for APs?
Also what is the latency when you remove the global network?
there must be possible broadcast or taking long route(due to STP)....causing the high latency..
