09-24-2009 10:09 PM - edited 03-06-2019 07:52 AM
hello,
i want to install a module GBIC SFP for multimode fx in switch 2960, i bought the module type MFEFX1, but when i put it in the 2960, nothing.
Is it a good module?
if it isn't the good, what type of model i have to buy for my lan access by optical fiber.
if it's good why it doesn't light?
thanks a lot for your answer
09-25-2009 03:14 AM
Who manufactured the SFP? If it ain't Cisco, you can't use it. A software in the software will interrogate the module and if it doesn't have the microcode, the appliance will disable the port.
Cisco SFP Optics For Gigabit Ethernet Applications
09-25-2009 05:10 AM
What is the exact part number of the gbic? I can tell you that inserting gbics into the 2960 can be a challenge. They don't always snap in the 1st, 2nd or 3rd time.
If it pulls out easily, it wasn't inserted. Pull it out and push it in with a little force. The clip on the bottom of the gbic will be all the way down and not half way up.
Aaron Magruder
NonStop Networks
