Warning message
reg:ipv6 labsetup
Sep 24th, 2009
Dear sir,
I have cisco 2800 router 4 numbers i connected back to back using null modem cables and i connected two xp ipv6 enabled pcs and how can i configure the router and how can i configure the pc
plz give me some examples.
Thanks&REgards
srini
simontibbitts Fri, 09/25/2009 - 01:20
  • Silver, 250 points or more
Hello.
So if you have connected all your routers and PCs up correctly then all you need to do on the PC is at the DOS prompt type 'ipv6 install'
On the routers you need to do the following:
ipv6 unicast-routing
interface FastEthernetX/X
ipv6 address [your address here]
This link should give you most of the information you need on configuring and understanding IPv6 on the Cisco routers:
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-addrg_bsc_con.html
Simon
