How do I apply an ACL to a LAN-to-LAN tunnel?
Answered Question
Sep 25th, 2009
I have an ASA with a active IPSec LAN-to-LAN tunnel and I'm wanting to limit what ports and IPs my extranet partner is able to reach. How do I apply an ACL to a LAN-to-LAN tunnel to limit ingress and egress traffic through the tunnel?
Thanks in advance!
Correct Answer by auraza about 7 years 3 weeks ago
It will work similarly. You need to use VPN filters. If you are using 8.0, then you can use the following doc:
Overall Rating: 5 (2 ratings)
anowell Mon, 09/28/2009 - 09:43
Thanks for the link but I am trying to limit access in regards to a LAN-to-LAN tunnel and not remote access. Any more thoughts?
Thanks in advance!
