Unity Connection 1.1 IP address change
Sep 25th, 2009
  • Bronze, 100 points or more
I have Unity connection 1.1 ( Windows Version) and want to change the ip address.I can't seem to find any documentation referring to this.I'm sure its quite straight forward just like changing any other windows box but i wanted to check.
regards
mark
Jaime Valencia Fri, 09/25/2009 - 10:42
  • Cisco Employee,
  • Hall of Fame,
    2011
AFAIK there is no doc for this but as you mention, it's just the same as changing the IP in any other Windows version by going to network connections
java
if this helps, please rate
