Sep 25th, 2009
Dear All,
I have 2 MCS-7825 server in site , also I have callmanager 4.2 , and as you know the maximum number of supported phones 1000 but unfortunately the number of Phones exceed this limit so IS there any scenario can be applied to solve this problem ? even if the two servers will be publisher and no redundance?? taking into your consideration I can't replace this hardware at this time.
your fast reply is highly appreciated.
Best Regards;
Hany Adel
Jaime Valencia Fri, 09/25/2009 - 06:20
Not really, you need to keep within the limits for Cisco support. If you can't upgrade the servers then the only other option is to take out phones.
Otherwise your current scenario is not Cisco supported.
if this helps, please rate
