NAC can't receive SNMP mac notification
Sep 25th, 2009
Is SNMP mac notification for switch really works with NAC OOB deployment? We have been trying to test in a POC setup for NAC where the PC with NAC agent is connected behind a Cisco and Nortel IP phones. Once the PC is disconnected behind the IP phone the NAC manager can't received snmp mac notifcation from the switch hence, the user is not automatically removed on the online users or certified devices. Were using NAC version 4.6 and C3750 switch version 12.2(35)SE2 and 12.2(35)SE5. We know there is a bug related regarding mac notification on switch ios version 12.2(25)SEC2 or lower but on stack switches. But were using standalone switches only for the testing and higher IOS version. Hope someone could help me verify on this on what specifically ios version of switch is working properly with snmp mac notification?
Thanks!
Wendell
Overall Rating: 0 (3 ratings)
draper7 Fri, 09/25/2009 - 06:48
I don't really have an answer to your question but this might help troubleshooting the problem.
SSH to the CAM and tail the following file (you'll need to be root):
[cam]# tail -f /perfigo/control/tomcat/logs/nac_manager.log
You should see LINK_UP / LINK_DOWN / VLAN switching events, etc from your managed switch. Also, you may want to see SNMP traffic.
[cam]# /usr/sbin/tcpdump -nn -i any port 162 or 161
Hope that helps.
-Dusty
pmccubbin Fri, 10/02/2009 - 08:54
  • Silver, 250 points or more
Hi Wendell,
We have been seeing this same bug for a week in a lab POC with a L3 VG OOB configuration with 4.6.1 code.
We have a 4506 running 12.2(46).
We changed to linkup linkdown in our configuration and that doesn't work any better than Mac-notification.
We are convinced we have a bug and will be looking for a scrubbed version of code.
Thank goodness we did a POC in a lab setting before doing a Pilot on the production network.
Hope this helps.
Paul
pmccubbin Fri, 10/02/2009 - 09:34
Try version 12.2(52) as I know it works with NAC 4.6.1 on a 4506.
pmccubbin Tue, 10/13/2009 - 09:17
Just had it confirmed by Cisco Tac. The 12.2(50) version of code is the oldest which they say will work.
This is from the Release Notes of NAC 4.7 and seems to explain it:
Open Caveats NAC
CSCsr95757
No
CAM intermittently stops processing SNMP MAC notification traps from the switch.
This issue can occur on different edge switches. Once the problem is present, no further SNMP MAC notification traps are processed from the CAM for the switch in question.
Note: There is no perfigo-log0.log.0 information, but a tcpdump from a CAM CLI session indicates that the CAM is receiving SNMP MAC notification traps.
Workaround: To re-establish correct SNMP trap handling on the CAM, open a CAM CLI session and enter the following commands:
service perfigo stop
service perfigo start
The CAM immediately starts processing the SNMP MAC notification traps from the problem switch(es).
Note: After a period of time, however, this problem may appear again.
FYI, the workaround didn't help in version 12.2(46) code on a 4506.
Here is the bug information from CCO:
CSCsr84693 Bug Details
Incomplete MAC notification SNMP trap on 4500s
Symptom:
Incomplete MAC notification trap is seen in 12.2(46)SG. The trap is missing some
fields
4: Mon 08/04/08 20:30:54
sysUpTimeInstance = 0d 0:04:10.83
snmpTrapOID.0 = CISCO-MAC-NOTIFICATION-MIB!cmnMacChangedNotification
cmnHistMacChangedMsg.3 = 02
cmnHistTimestamp.3 = 0d 0:04:10.83
A complete traps looks like the following:
sysUpTimeInstance = 0d 0:07:14.16
cmnHistMacChangedMsg.2 = 01:00:01:00:11:00:22:00:33:00:47:00
cmnHistTimestamp.2 = 0d 0:07:14.16
Thus, in cmnHistMacChangedMsg attribute, the following fields are missing:
MAC Address
Dot1dBasePort
Conditions:
This problem is seen whenever a Mac notification trap is sent.
Workaround:
Use CLI "sh mac-add not change" in 12.2(46)SG.
Use a different software release; eg., 12.2(44)SG
Hope this helps.
