eBGP multihome question
Answered Question
Sep 25th, 2009
Hi Everyone.
I have a question, I have 2 routers R1 in building #1, R2 in building #2 each having a different ISP with full routes. there is also a link between each router for traffic between the building and each building has their own /24.
what I would like to do is load balance the ebgp sessions and have backup incase one fails.
from what I have read I need to do the following:
1) a iBGP session between the router
2) include both network in both routers BGP config
3) prepend the network from the other building.
example
BGP in building A
router bgp 1111
network A.A.A.A
network B.B.B.B
prepend network B.B.B.B
BGP in building B
router bgp 1111
network A.A.A.A
network B.B.B.B
prepend network A.A.A.A
Thank you in advance
Correct Answer by mszeftawy about 7 years 9 months ago
Hi hcintron
One more point should be taken in consecration.
You have to create proper filtering for the routes sent from your routers, only advertise your range of addresses.
I mean don't rely on your service provider to filter the routes that came from your network, in case one of your service providers is not performing the proper filtering you will advertise provider A subnets to provider B and vise versa, which might make them use your network as a transit AS for the intra-provider traffic.
Correct Answer by Giuseppe Larosa about 7 years 9 months ago
Hello Hector,
your action plan looks like correct.
only point that if you want to perform selective prepending you need to use a route-map
access-list 11 permit B.B.B.B
route-map sel-prepend permit 10
match ip address 11
set as-path prepend yourASN yourASN yourASN
R1
router bgp yourASN
neigh isp.ipaddr route-map sel-prepend out
the same has to be done on R2
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Correct Answer
Giuseppe Larosa Fri, 09/25/2009 - 11:04
  • Hall of Fame,
    Founding Member
Hello Hector,
match ip address 11
R1
router bgp yourASN
Hope to help
Giuseppe
Correct Answer
mszeftawy Fri, 09/25/2009 - 11:42
Hi hcintron
hcintron Fri, 09/25/2009 - 14:58
Great.
Thank you Giuseppe and mszeftawy for letting me know that I was in the right track and the pointers.
