LMS 3.2 upgrade failure?
Sep 25th, 2009
I upgrade to LMS3.2 from 3.0.1 and now I don't see TAB for
Common Services, I see a new TAB "setup Center" but no TAB for CS where
I can click device discovery etc. Attached is the screen shot
nawas Fri, 09/25/2009 - 07:45
Anyone have clue, How do I get the CS back?
nawas Fri, 09/25/2009 - 10:58
I think my upg, rade failed with tons of errors: don't understand why I got this error though while my cluster patch is up to date (I'm on Solaris 10)
WARNING: Ensure that you have installed the recommended Solaris 10 cluster patches released
WARNING: on Apr/17/07, in this server.
I also tons of errors for the following, im copying only the few.
WARNING: Exiting installation beyond this point might result in system instability.
ERROR: The following base package image is bad: CSCOsjre.
ERROR: The following base package image is bad: CSCOmd.
ERROR: The following base package image is bad: CSCOcsjre.
ERROR: The following base package image is bad: CSCOperl.
ERROR: The following base package image is bad: CSCOxml4j.
ERROR: The following base package image is bad: CSCOhlp.
ERROR: The following base package image is bad: CSCOxsl.
ERROR: The following base package image is bad: CSCOjcht.
ERROR: The following base package image is bad: CSCOcam.
ERROR: The following base package image is bad: CSCOxrts.
ERROR: The following base package image is bad: CSCOsnmp.
ERROR: The following base package image is bad: CSCOjgl.
ERROR: The following base package image is bad: CSCOplug.
ERROR: The following base package image is bad: CSCOdb.
ERROR: The following base package image is bad: CSCOcsorb.
nawas Fri, 09/25/2009 - 11:01
I'm getting ready to do the install again, I have increased the swap file size to 10GB and disk space to 40 GB, any other suggestion before I try this again?
