LACP EtherChannel
Sep 25th, 2009
I am trying to configure LACP between our Cisco 3750 stack and an EMC SAN.
I have 2 GigabitEthernet ports that I have put into port-channel 20, please see the below config for the 2 interfaces…
interface GigabitEthernet2/0/10
description EMC
switchport trunk native vlan 101
switchport mode trunk
speed 1000
duplex full
channel-protocol lacp
channel-group 20 mode active
interface GigabitEthernet2/0/12
description EMC
speed 1000
duplex full
When using the above configuration the links do not come up, the port-channel interface and 2 physical interfaces show as notconnect.
However, when I switch the mode to 'on' (therfore not use a protocol) the etherchannel comes up no problem.
I have been assured that the EMC SAN is configured correctly and is able to use LACP.
I have also tried 'passive' mode with no joy!
Any help is greatly appreciated.
Steve
glen.grant Fri, 09/25/2009 - 06:36
  • Purple, 4500 points or more
The switch side looks fine , without seeing the san side which is where the problem probably is it's hard speculate. If it works as "on" then maybe the san is set as on also .
Giuseppe Larosa Sat, 09/26/2009 - 04:00
  • Hall of Fame,
    Founding Member
Hello Steve,
probably the EMC SAN is not sending LACP messages and the switch after a timer expiration puts the ports in a suspended state.
Check the switch log for LACP related messages with
sh log | inc LACP
By the way, this is the advantage of LACP it can detect problems with the neighbor device.
Hope to help
Giuseppe
