Monitoring Object tracking with SNMP
I need to find a way to monitor via SNMP or Syslog how to monitor the object tracked routes on a ASA 5505.
When my connection fails over from cable to dsl or vice versa I'd like to recieve a alarm or email via Cisco Works or Whatsupgold.
Below is part of the configuration
track 3 rtr 3 reachability
track 4 rtr 4 reachability
sla monitor 3
type echo protocol ipIcmpEcho interface backup
frequency 15
sla monitor schedule 3 life forever start-time now
sla monitor 4
type echo protocol ipIcmpEcho interface outside
frequency 15
sla monitor schedule 4 life forever start-time now
yjdabear Fri, 09/25/2009 - 07:23
It seems ASA's IP SLA configs are not as far along as that of IOS, in terms of alerting.
I suppose you could either roll your own and write a "robot" script to log into each ASA to parse the "sla monitor" output accordingly, or configure the IPM piece of CiscoWorks LMS to do it for you: IPM - Collector Mgmt - Operations - Generate Action Event - Event Type: SNMP Trap.
Joe Clarke Fri, 09/25/2009 - 09:21
The robot script would have to be the way as the ASA does not support the CISCO-RTTMON-MIB, therefore IPM will not be able to manage them.
yjdabear Fri, 09/25/2009 - 09:28
Would you know when CISCO-RTTMON-MIB support would be added, or the ASA IP SLA capabilities be expanded to match the IOS?
Joe Clarke Fri, 09/25/2009 - 09:33
No idea. This is the first time I heard about IP SLA support in the ASA. I haven't seen any ASA IP SLA SRs in the NMS TAC, and I'm not seeing any enhancement requests pending.
Joe Clarke Tue, 10/13/2009 - 13:57
There is no MIB support in the ASA to support tracking. There is just no way to do it with SNMP.
