bvi and vlan traffic through router
Sep 25th, 2009
I have a 2811 router with a single BVI to a 2960 switch with 3 vlans. There is a transparent firewall on the 2811 router. Currently, traffic between 2 nodes on the same vlan segment traverses the transparent firewall causing latency. Is there a way to configure the vlan on the switch such that traffic will not be passed through the firewall when not leaving the vlan?
For example, a LAN based Nessus scan of hosts on VLAN1 from a port on VLAN1 causes the utilization on the router memory and processor to 100%. Thanks,
Dave
John Blakley Fri, 09/25/2009 - 09:02
Are you running CBAC or a zone based firewall? Where is the policy for the firewall applied?
HTH,
John
ruessd-wawa Fri, 09/25/2009 - 09:11
Zone based firewall, policy is applied to the BVIs. Such as
policy-map type inspect BVI1
