Pre attend
Sep 25th, 2009
Is it possible to play a message to a caller before the call is answered? I am not talking playing a message when you are in a queue, i mean when you call a service you always get a message. I don't have Unity or IPCC. Just CUCM 6.1
Thanks in advance.
Overall Rating: 4 (2 ratings)
Jaime Valencia Fri, 09/25/2009 - 09:59
  • Cisco Employee,
  • Hall of Fame,
    2011
Not with just CUCM, you need Unity, CUC or UCCX/UCCE.
CUCM is just a call control agent and has no place to record or configure this behavior.
java
if this helps, please rate
Jonathan Schulenberg Fri, 09/25/2009 - 19:45
  • Cisco Designated VIP,
    2017 IP Telephony
You could also use a TCL script on the gateway before routing it to CUCM, but I wouldn't recommend it.
