CLI/ASDM limits via ACS for FWSM
Sep 25th, 2009
I am looking for suggestions to the attached docs. My situation is that I need to seperate some of the managment functions of the FWSM into 2 groups.
Group1 should be able to configure IOS/perform chassis operations/FWSM system context functions/routing configuration per contexts.
Group2 should be able to configure context related things like ACLs, object-groups, NAT, etc.
Currently I do not have access to the devices or ACS with which to test. When access occurs, it will be in the order of ACS first, then FWSMs second.
Will the items in the attached files provide the access that I have described above?
Thanks in advance
