851 Router SDM Wizard not working
Lucien Avramov Fri, 09/25/2009 - 10:25
  • Red, 2250 points or more
This is most likely due to not using the supported java runtime environment JRE version.
SDM does not support java after: 6u3.
Cisco SDM requires Sun Java Runtime Environment (JRE). The following versions are supported:
•JRE 1.5_09
•JRE1.4.2_08
•JRE 1.5.0_06
•JRE 1.5.0_07
•JRE 1.6.0_02
•JRE 1.6.0_03
As per the release notes.
http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/software/release/notes/SDMr25.html
Also configuration guide may be handy:
http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/25/software/user/guide/SDM25UGD.html
