SWVMS16
Sep 25th, 2009
I'm interested in Cisco cams using SWVMS16.  I've seen two different OS requirements.  A Ccisco page said that it would work with XP and Vista 32 and 64-bit.  The admin guide said that it would work with Server 2003 but no bit specs.  Ideally I would like to use this on Server 03 or 08 64-bit.  Anybody know if this is possible?
Thanks,  Ryan
clindoan Fri, 09/25/2009 - 13:19
The SWVMS16 Video Monitoring System is working with any of the 32 bits and 64 bits hardware and OS. Here are the OS that had been tested (All version of XP and Vista, 2000 server, 2003 server, and 2008 server).  Testing for Windows 7 is under way to verify if there is any issue.
