09-25-2009 12:26 PM - edited 03-10-2019 04:46 AM
After shutdown the sensor from IME gui under configuration > sensor mgmt, sensor was accessable only from console.
Can't even ping to it.
Please help. Thanks,
09-25-2009 12:55 PM
Get on the CLI and issue a "reset" command.
09-25-2009 04:25 PM
I have never use reset on ips.
Would it wipe out all and set to default?
I don't want to lose the configuration.
09-28-2009 04:16 AM
This will only 'reset' (reboot) the appliance. It will not have any affect on the configuration. To shutdown you can use 'reset powerdown'.
Farrukh
