remove ACL in FWSM
Sep 25th, 2009
I could not remove the firewalls in our FWSM with "no access-list ..." I did not see ACL identifier word when I type "no access-list ?".Our image is 3.2(10). I am wondering if any bug caused it or I use wrong way. Please advice!
Thx
Overall Rating: 5 (1 ratings)
Yudong Wu Fri, 09/25/2009 - 14:21
"no access-list" is not supported. You need use "clear config access-list ".
HWangLoyalty_2 Mon, 09/28/2009 - 06:01
Just tried it with "clear config access-list ", it still did not work for removing specific ACL.It looked like all rules was removed. any idea?
THx
Yudong Wu Mon, 09/28/2009 - 07:22
You should be able to delete individual ACL entry by "no access-list".
Here is the example.
FWSM(config)# sh run access-list test
access-list test extended permit icmp any any
access-list test extended permit tcp any any
access-list test extended permit udp any any
FWSM(config)#
FWSM(config)# no access-list ?
configure mode commands/options:
alert-interval Specify the alert interval for generating syslog message
106001 which alerts that the system has reached a deny
flow maximum. If not specified, the default value is 300 sec
deny-flow-max Specify the maximum number of concurrent deny flows that can
be created. If not specified, the default value is 4096
optimization Configure ACL group optimization
ERROR: % Incomplete command
FWSM(config)#
FWSM(config)# no access-list test permit tcp any any
FWSM(config)# Access Rules Download Complete: Memory Utilization: < 1%
FWSM(config)#
