LMS removing Subnet
Sep 25th, 2009
How do I excluce a 10.254.2.0 subnet from a user tracking ping sweep (LMS 3.1).
I was unable to exclude as the subnet is not listed.
Which subnet does LMS automatically shows over there?
-Thanks
Overall Rating: 5 (2 ratings)
Joe Clarke Fri, 09/25/2009 - 13:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
UT will ping all of the subnets listed in the NMSROOT/campus/etc/cwsi/RouterData.xml file. If a router with that subnet has not been Data Collected, then ping sweep will skip it.
georgeef1 Sat, 09/26/2009 - 06:26
Thanks Jclarke,
So is there a way to remove a specific subnet or exclude sort or setting in LMS either via GUI or any file modification.
-Thanks
Joe Clarke Sat, 09/26/2009 - 06:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
To exclude a subnet which has been found by Campus, go to Campus Manager > Admin > User Tracking > Acquisition > Ping Sweep. If the subnet isn't showing there, then Campus hasn't found it, and it won't be pinged anyway.
