How to setup provisioning report rule
bilutelvoip
Hello, I can understand that you can get configuration status from SPA2102 using a http//server/somedirectory/file.xml, I have tried that but nothing happening. DO I need to handle the POST from the device (how?) or I can only get it after requesting it?
The bottom line is I need help on how to monitor whether a device has downloaded the configuration file from my http server.
paolo bevilacqua
Unlikely that you will get an answer here.
Check SPA provisioning guide, easy to find.
I have gone through the guide and manage to make config files and have the devices retrieve them, but the section on report rule is very short and not much is described.
I read somewhere in the provisioning guide that one can purchase Remote configuration (RC) unit from cisco. Any idea how I can do that?
Thanks.
