CUCM 7.1(2) Combined Network Locale vs Cisco 7905/7911
Sep 26th, 2009
I've just installed the combined network locale package file to use the Canadian locale on my phones. It worked for my 79x1/79x2 phones but not for my 7905/7911 phones. I am unable to select Canada but United States shows up with all the other locales. Am I doing something wrong or do I have to install a different locale file for these phones?
(I'm using the Canadian locale because I cannot stand the 2nd Dial Tone sound from the US ;-))
gogasca Mon, 09/28/2009 - 22:44
  • Green, 3000 points or more
Hi Jean,
- Which is the Combine file you use?
Locales for CUCM 7.1.1 and CUCM 7.1.2 work only with LI 7.1.2.x. CUCM 7.1.3 work only with LI 7.1.3.
- If you define Network Locale at Device Pool level what happens?
- Cisco Unified Communications Locale Installer MUST be applied to each and every Cisco Unified Communications Manager server in a cluster, starting with the publisher. After installation has completed, it is essential to reboot each and every platform in order for all user and network locale changes to become fully activated.
Let us know
