09-26-2009 10:50 AM
Dear all,
Does someone has a document listing all default threshold value on Device Fault Manager (DFM) of LMS ?
Particularly, I need to know the thresholds for :
- Interface HighUtilization alert, and
- Interface HighQueueDropRate.
Thanks in advance.
Solved! Go to Solution.
09-26-2009 11:47 AM
09-26-2009 11:27 AM
DFM defaults:
Backplane utilization threshold 80 %
Memory buffer miss threshold: 10 %
Free memory threshold 15 %
Memory fragmentation threshold 5 %
Memory buffer utilization threshold 90 %
Processor utilization threshold 90 %
You can check the default settings for thresholds
DFM > Configuration > Polling and Thresholds > Managing Thresholds
There you can choose from the default groups, and look for the group where you got the HighQueueDropRate from, if its for example and 10-100 Mbit eth interface, than you should go to Interface Groups, 10MB-100MB Ethernet group, and click EDIT.
09-26-2009 11:34 AM
Hi Lucien,
Thanks for prompt reply.
I saw these thresholds related to device performance but not interface.
Do you have values for 100 Mbps Ethernet:
Thanks.
09-26-2009 11:47 AM
Utilization: 40 %
Queue Drop Rate: 1%
09-26-2009 11:52 AM
Many thanks Lucien.
Much appreciated.
