FXO goes offhook before the other end pickup
Sep 27th, 2009
the scenario is: Phone - CUCM4.2 - VG12.4(11)XW8 - FXO - PSTN.
the FXO goes offhook before the other party over the PSTN pickup the call, this indiscate the call start getting charged.
paolo bevilacqua Sun, 09/27/2009 - 05:49
  • Hall of Fame,
    Founding Member
Are you using mgcp or h.323 ?
paolo bevilacqua Mon, 09/28/2009 - 04:41
  • Hall of Fame,
    Founding Member
Then configure "plar opx".
paolo bevilacqua Mon, 09/28/2009 - 04:55
  • Hall of Fame,
    Founding Member
Can you clarify if you are talking about incoming or outgoing calls from the CUCM.
paolo bevilacqua Mon, 09/28/2009 - 07:31
  • Hall of Fame,
    Founding Member
CUCM has cannot influence in anyway about billing outgoing calls.
FXO must go off-hook in order to dial, and you should be billed only if remote answers.
mohdashraq Mon, 09/28/2009 - 09:06
appreciate your cooperation, the problem is that the FXO goes offhook before the remote party pickup the call, means the charging start even if the remote end doesn't answer.
paolo bevilacqua Mon, 09/28/2009 - 09:12
  • Hall of Fame,
    Founding Member
What I'm trying to tell you, it is normal since the invention of telephone, that a calling FXO goes off-hook, as it is a necessary condition to dial.
For example, when you are home, you lift the handset (this means off-hook) and dial. If no answer, you hang-up (meaning you go on-hook) and are not billed.
So check again with your telco.
Please remember to rate useful posts with the scrollbox below.
wdejulio312 Thu, 09/30/2010 - 15:05
I think im having the same issue but different
Basically I need to make an incoming call from the PSTN -> FXO port ring an inside IP phone but not go OFF-HOOK on the FXO until the IP Phone picks up. The customer wants to ring-no-answer after 5 seconds from the telco to another phone number on the PSTN.
Thanks!
Warner
Chicago IL
