SIP Gateways
Answered Question
Sep 27th, 2009
I am looking for Cisco products that can act as SIP gateways. These products need to be priced for the SMB market. We implement the SIP gateways by using available BRI or PRI ports on the clients existing PBX (provided it is not an IP PBX). The gateways will need to provide 16-32 concurrent outbound calls using G.729a codec. We use the PBX dialing plans to decide on how calls are routed. Local calls typically will be routed over the PSTN, but national, mobile, on net and international will be routed via VoIP. Internet connectivity is either through DSL or channelized E1. Please advise on the recommended Cisco products that will be effective for this type of operation.
Correct Answer by paolo bevilacqua about 7 years 10 months ago
The coding/decoding is done by dedicated DSP so not much of an issue. There is a full lineup of ISR voice router with 7 models up to the 3845.
Please remember to rate useful posts with the scrollbox below.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Sun, 09/27/2009 - 05:42
  • Hall of Fame,
    Founding Member
The smaller router you can use for this is a 1861. then you have to add pvdms-16 or 32, and the interfaces.
Recommend you work with a reputable partner or reseller because in most cases when the end users tries doing alone, either makes the wrong purchase or are unable to configure and make it work.
PeterDownes Sun, 09/27/2009 - 05:50
Thanks for the advice. I will work with our local distributor, but I have been getting mixed messages.
Does this router (1861) support SIP and the G.729a codec for the RTP stream? How many concurrent calls will this device be able to manage?
paolo bevilacqua Sun, 09/27/2009 - 05:59
  • Hall of Fame,
    Founding Member
Yes it does and with an E1 PRI it would support 30 calls.
That's why I said you need to locate a competent partner, there is a lot of people around that doesn't know or knows wrong, but still talks.
PeterDownes Sun, 09/27/2009 - 06:03
My concern is regarding the processing capacity of the device. The load created by the encoding can be a bottleneck on these devices. For the record...what is the maximum number of G.729a concurrent calls this device will support...is it 30? If I needed a bigger device for more calls, what would the next device upwards be?
Correct Answer
paolo bevilacqua Sun, 09/27/2009 - 06:11
  • Hall of Fame,
    Founding Member
