# issue with E1
Sep 27th, 2009
Dear Friends,
I'm facing an issue, when I dial the DID of the call centre and trying to insert # as input (as menu ask to insert # to repeat the menu) I got message (which uploaded in case of customer time out without input) telling plz insert choice, which means that the system not accepting # as button, however all the digits is working fine including *
Any idea? appreciate your support as usual
Mohamed Gheta
mohamed-gheta Mon, 09/28/2009 - 04:56
Thanks so much for your concern, no problem, I will keep searching
Have a nice day,
sebastiandm Mon, 09/28/2009 - 05:28
Have you got the dtmf-relay rtp-nte h245-signal h245-alphanumeric command configured under your voip dial-peer ?
mohamed-gheta Mon, 09/28/2009 - 05:46
Hi Friend,
Actually I'm using ;
dtmf-relay h245-alphanumeric
As I'm using R2 not ISDN PRI
So you recommend to use this instead
