Secondary Dial Tone
Paolo Bevilacqua Sun, 09/27/2009 - 06:44
  • Hall of Fame,
    Founding Member
No, it does not.
You will find that secondary dialtone is not of much use anyway because most users learn to compose the full number then press dial. They do not wait for dialtone at all.
p.bevilacqua,
Thank you so much for the reply.
Because this UC520 share by 2 department and ISDN line charge by individual department.
Could you advice me what is the better way to control outgoing call? Because I want them to have different way to access outgoing call.
can I still make them to press 1 digit to access outgoing call then follow by the number?
Paolo Bevilacqua Sun, 09/27/2009 - 07:15
  • Hall of Fame,
    Founding Member
You can have the access digits as you like.
You can also have the GW to use one or another BRI depending on who's calling, and not use digits at all:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801c0a88.shtml
Note you need the translation-profile to be under ephone-dn for this.
The same cans alos be done with COR and no number manipulation.
Please remember to rate useful posts with the scrollbox below.
