NAC appliance & NAC guest server integration
Sep 27th, 2009
i have NAC appliance deployed in L2 OOB virtual gateway, & integrated with NAC guest server , the problem is when i create guest account on the guest server , it doesn't be created on the CAM , & on the guest server appliacation logs i find the following error:
_SYSTEM_ Process failed 27-Sep-2009 17:35:03
_SYSTEM_ Message: Invalid argument supplied for foreach(); Type: Warning (2); Filename: CleanAccessManager.class.php; Line: 323; Script: BatchProvisioning.php 27-Sep-2009 17:35:03
_SYSTEM_ Updated guest account status to active: [email protected] 2016 27-Sep-2009 17:35:02
_SYSTEM_ (192.168.40.2 - LAB_CAM) Prepared provisioning of account: [email protected] 2016 27-Sep-2009 17:35:02
sponsor Guest account created: [email protected] 2016 27-Sep-2009 17:35:00
Faisal Sehbai Sun, 09/27/2009 - 09:04
  • Gold, 750 points or more
Hany,
If you're using the latest version of Guest server (2.0.1), this might be CSCtb52569.
That bug is slated to be fixed in 2.0.2. If you want a patch, please open a TAC case and mention this bug and the symptoms you're seeing to the TAC engineer.
HTH,
Faisal
