asa 5505 config with public ips inside dmz and nat help.
hello there,
I have an asa 5505 with a /29 block, configured with the normal 1-1 static mapping in my dmz (to internal ips).
The problem starts now that i have one server that need to have a public ip address physically on it.
the only way i see to get this is to put the server in the outside vlan, but when i do this i have not ACL control of the traffic that goes IN the interface??
this is where i need help, how can i give the server a public ip, yet keep it behind some acl and firewall rolls.
(as if it goes in the outside interface i need to install a firewall on the server which makes no sense)
hope all this made sense to someone :).
any ideas let me know.
Thanks in advance and have a good one.
Yudong Wu Sun, 09/27/2009 - 22:30
If you could subnet your /29 block further, then you can use a pair of public IPs, one on DMZ interface and the other on your server and add a static NAT.
static (dmz,outside) Server-Pub-IP Server-Pub-IP
