09-27-2009 05:56 PM - edited 03-06-2019 07:53 AM
Greeting,
Is there a difference between the network command and redistribute connected in OSPF i just notice that when i use redistribute connected (to advertize all my connected networks without using the network command) i don`t have the loadbalancing feature however when i issue the network command for at least one connected network i will see the redundant path on my ospf routing table.
To summurize:
Area 0 ==R1(area 1 NSSA) ========= R2 (Area 1 NSSA loop 172.16.1.0, 192.168.1.0)
When i type in R2
router ospf 1
log-adjacency-changes
area 3 nssa
redistribute connected metric 100 subnets
network 10.10.10.0 0.0.0.255 area 3
network 10.10.12.0 0.0.0.255 area 3
I can only see One path to my loop in R1
however when i issue these commands:
router ospf 1
area 3 nssa
network 172.16.1.1 0.0.0.0 area 3
Now in R1 i can see two redundant path to my loopback
any explanation?
09-27-2009 11:01 PM
Hello Seifeddine,
there are difference between the two options and where possible I would recommend to use network area command.
Regarding your specific issue I would suggest you to post
sh ip ospf database external 172.16.1.0
sh ip route 172.16.1.0
on R1
Hope to help
Giuseppe
09-28-2009 04:55 AM
Hi Giuseppe
Thanks for your message, well my question is why with the network command i can get the two path for 172.16.1.0 and with the redistribute command i can`t.
Can you try to simulate this using dynamips
