SSHv1 / SSHv2 support for Cisco IOS on VG224
Sep 28th, 2009
We are trying to configure the SSHv1 or SSH v2 on VG224 with vg224 Software (vg224-I6S-M), Version 12.4(12)(vg224-i6s-mz.124-12), however there doesnt seem to be any supported commands on the IOS release.
Anyone tried SSH configuration on VG224 analog gateways, and which IOS release to be used?
Thanks.
Overall Rating: 4 (2 ratings)
Jaime Valencia Mon, 09/28/2009 - 03:45
The IOS you're using does not support SSH
It needs the IP SUBSET/IPSEC 64 BIT/VOICE
The IOS name should contain a K9 in case it's enabled for it
IE
vg224-i6k9s-mz.124-15.T5.bin
java
if this helps, please rate
bberry Mon, 12/10/2012 - 13:27
I am running 12.4.22.T5 and can only get SSH V1 to operate. If I specify SSH V2 I get no connection. I am using a 2048 modulus on the key. Any thoughts?
Indu Gudipati Fri, 02/15/2013 - 12:30
We  have the same issue too, we have IOS  vg224-i6k9s-mz.150-1.M3.bin and higher on our VG 224's .
Never able to get SSH v2 working on the them, SSH v1 works fine .
also we use a modulus 1024 key .  Some body advise ??
Indu.
