DHCP Snooping and Dynamic ARP Inspection
Sep 28th, 2009
In order to reduce the impact of ARP spoofing attacks, I would like implement DHCP snooping and dynamic Arp inspection feature features on our Cisco enterprise network.
Test were conclusive for all devices connected directly to cisco switches.
However, I still have problems with devices connected to SOHO unmanaged switches.
Could you indicate me please, how I can overcome this problem.
You can find in attachment an example diagram.
Printer1 and PC2 cause connectivity problem when port Fa0/23 on switch S2 is configured as untrusted.
When I configure that port as trusted, I still can operate successfull ARP spoofing attacks with Cain & Abel software.
Best Regards,
Mustapha
Giuseppe Larosa Mon, 09/28/2009 - 02:12
Hello Mustapha,
indeed DHCP snooping and DAI would fit with a design where no unmanaged switches are present so that a one-to-one corrispondence between MAC addresses of PCs and printers and ports can be done.
in your case you could just use port security with DHCP snooping trusted state as a way to mitigate at least MAC flood attacks.
Hope to help
Giuseppe
