09-28-2009 05:57 AM - edited 03-18-2019 11:45 PM
Hello, can anyone help please. I am not sure what the options are for Unity resillience. I have seen failover and standby redundancy options on CCO. What is the difference? Do you have to have an external Exchange server or can it be configured on the local Unity servers alone. I will have 2 servers for Unity and have to provide a resillient system using Unity v7.x. Please advise. Thanks.
09-28-2009 06:13 AM
Here is the doc for standby and failover for 5.x version. Same applies to 7.x too.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/design/guide/5xcudg070.html
A simple search on cisco.com for Cisco Unity Standby would get you there. Also, 5.x and up, you can have the Exchange either off box or on the secondary server.
See here:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/installation/guide/vmexfo/5xcuigvmefo060.html
Again, this is for 5.x but is used for 7.x version as well. Both options are there.
Tray
09-28-2009 06:28 AM
Hi Tray, thank you for replying.
Just to clarify: I could install Unity on 2 servers. The secondary server is the one that I would have local Exchange configured on. I could either have them in Failover mode (in same datacentre) where they have real time sync of message store; or i can have them in standby mode (in different datacentres 100Mb WAN) where the sync of messages is done once a night. In both cases I think I need sql2000 on both servers. Does this sound right?? Thanks
09-28-2009 07:06 AM
09-28-2009 07:21 AM
SQL 2000 is the only supported SQL in failover deployment. As far are the different requirements for this type of deployment, please read the Unity 5x design guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/design/guide/5xcudgx.html
Tray
