Catalyst WS-C2960-48PST-L
Answered Question
Sep 28th, 2009
Someone Please tell me:
Is this switch WS-C2960-48PST-L capable of powering up cisco IP Phones on all the 48-ports?
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_bulletin_c25-512173.html
The description is a bit confusing.
Correct Answer by Leo Laohoo about 7 years 8 months ago
That's not confusing. Here's the confusing bit ...
The WS-C2960-48PST-L is a 48-port switch WITH PoE support (15.4w or less per port) to only 24 ports. Which 24 ports? The first 24 ports in a first-come-first-serve basis. So if you have 25 PoE "stuffs" (even though these draw less than 15.4 watts each), the switch will only provide the first 24 leaving the 25th dark.
Does this help? I hope it does because when this was first explained to me I was told that I had a very blank look.
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 09/28/2009 - 07:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Nicholas
From the link -
"Catalyst 2960-48PST-L configuration can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W"
So the answer is it depends. And it depends on how much power your phones need to draw to work. Which phone set are you using ?
Jon
Correct Answer
Leo Laohoo Mon, 09/28/2009 - 14:35
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
jmandersson Wed, 09/30/2009 - 01:36
Really?
How come that the product-pdf says: the "...support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between."
So if I connect 48 of the Cisco 7960 (5w each) to the 2960-48PST-L, it won't work?
Please explain it for me
I'f you right I will also have a very blank look...
Best regards,
Johan
Leo Laohoo Wed, 09/30/2009 - 15:12
  • Hall of Fame,
    2017 LAN, Wireless
Hi Johan,
In my experience, if you plug 48 into it, 24 will power up. The rest will go blank.
But, I'll be very happy if someone can prove me wrong. :)
Leo Laohoo Tue, 09/29/2009 - 14:40
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the rating.
