transfer softkey isn't presenting
Sep 28th, 2009
I have a user that is claiming she doesnt have "transfer" as a softkey option. I have the same softkey template as her and mine is there 100% of the time.
She says that hers isnt there sometimes when she is connected. it happens more often when she is on multiple calls that transfer isnt available.
I am skeptical, but I thought I would throw it out to you guys to see if there is a known issue or parameter I can check.
Overall Rating: 4 (2 ratings)
Jaime Valencia Mon, 09/28/2009 - 06:29
If the # of calls on the line = maximum calls on line then conference and transfer would be grayed out and wouldn't work.
Not sure if that's what she's seeing.
if this helps, please rate
scott.hammond Mon, 09/28/2009 - 07:28
checked that....
She said it was 2 calls and she has a limit of 4 lines, which should be ample. I will pull the number down though and see if I get the same symptoms.
scott.hammond Mon, 09/28/2009 - 08:00
She is the only 7965 on my system so Im going to try updating her firmware.
Now if I could just remember how to upload firmware....
I have had a user that had a similar "problem". In my case it turned out that the user was having a call coming in and she wanted the transfer the call she was on before she answered the incoming call. But when the phone is in "ring in" status it has different softkeys than when it's in "connected" status. I showed her how to use the toggle switch in the middle of the phone to highlight the call she wants to work with and then transfer the call.
