7206 VXR NPE-G2
Sep 28th, 2009
can i know whether 7206 VXR NPE-G2 rputer is hot swappable because we are having 2 7206 router which is having additional card inserted and we need to remove from one router and to place on the other router
can i do we its in live ?
Slot 1:
Gigabit Ethernet Port adapter, 1 port
Port adapter is analyzed
Port adapter insertion time 28w4d ago
EEPROM contents at hardware discovery:
Hardware revision 1.1 Board revision B0
Serial number 27704720 Part number 73-3144-05
FRU Part Number PA-GE=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 98 01 01 01 A6 BD 90 49 0C 48 05 00 00 00 00
0x10: 58 00 00 00 00 00 00 00 00 01 FF FF FF FF FF FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF
Slot 2:
Serial number 27185976 Part number 73-3144-05
0x00: 01 98 01 01 01 9E D3 38 49 0C 48 05 00 00 00 00
slmansfield Mon, 09/28/2009 - 07:33
According the documentation on CCO, it looks like "all port adapters and service adapters in the Cisco 7200 VXR routers support online insertion and removal (OIR). However, it is wise to shut down the interface before removing a port adapter that has active traffic moving through it. Removing a port adapter while traffic is flowing through the ports can cause system disruption. Once the port adapter is inserted, the ports can be brought back up."
Here is the URL for more details.
http://www.cisco.com/en/US/docs/routers/7200/install_and_upgrade/7200vxr_install_config/5013ov.html#wp1016065
