ASA 5505 Viso Stencil
Sep 28th, 2009
I saw the previous message about the ASA icon's and stencils. However the download for the ASA 55xx stencils does not include one for the 5505. Is there one available? Thanks.
Overall Rating: 0 (3 ratings)
mimeyer Mon, 09/28/2009 - 08:08
Craig --
Currently there is only one icon, and a text label is used to identify the unique product in the 55xx series. However, your request raises the issue that perhaps a separate icon would be useful. This suggestion has been forwarded to the Cisco ASA 5505 product team.
ougwuoke Mon, 12/12/2011 - 13:30
hello Tcording,
If you still have the 5505 stencil/icon can you please email it to me
tcording Sat, 01/30/2010 - 02:16
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Hi Craig
Better late than never
If you still need these let me know and I can email you the stencil
Craig.Nelsen_2 Mon, 02/01/2010 - 06:16
Hey, thanks for getting this done. Yes I would love to have the stencil so I can get rid of the generic icon I used in my net diagrams.
leiTech12 Mon, 02/01/2010 - 19:51
wow that stencil looks great! i would really appreciate a copy of this also. i've been using the 5510 or more often than not a png graphic i made of a photograph i took of the back of one of our units. this trumps both by far.
many thanks for your effort.
cvestal11 Fri, 08/26/2011 - 08:13
Very Nice!  The current stencil set from Cisco as of 8/26/2011 doesn't have an ASA5505.  I'm glad you posted this
caid-iops Tue, 02/23/2010 - 03:54
Very nice...
But!  Port numbering on front and back of ASAs starts at 0 and ends with 7.  I tried editing the stencil, but it threw out a bunch of things.
caid-iops Tue, 02/23/2010 - 04:49
Ok - I've updated this with images of the correct numbers over the top of the original stencil.
Reason this is important to me is that we deploy ASAs pre configured and want to be able to tell local staff exactly how to connect everything up.  Diagram has to look exactly like the physical device, else mistakes get made.
