Guest Access on WLC - No WCS
Sep 28th, 2009
Is there a way to configure guest access on a WLC using open authentication? I don't have a WCS server and do not want to use web based. I want something very simple that allows guest to automatically connect to APs. Thanks
Robert.N.Barrett_2 Mon, 09/28/2009 - 09:00
  • Bronze, 100 points or more
You can configure an additional SSID with no authentication. You'll probably want to enable SSID broadcast (to make it easy for guest computers to find the network), and you'll definitely want to put it on a separate VLAN so that you can route it properly (keep it separate from your private VLAN).
flyingmunk Mon, 09/28/2009 - 09:24
I meant to say no ACS or RADIUS server, but I'll assume from the reply that this doesn't make any difference. Thanks
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
