SPA9000, Sip-b supported on FXS ports?
Sep 28th, 2009
Hello!
I am trying to find out if the 2 FXS ports on the SPA9000 are supporting the SIP-B.
While the SPA ip-phones have an explicit option that enables/disables this feature,
the FXS lines are missing it completely, will this mean that the FXS ports do not
use the SIP-B extensions?
Unfortunately I cannot find any confirmation on the SPA9000 admin guide.
I am trying to find this out because I noticed a strange behavior of the FXS ports when
added to an hunt-group.
Luca
Patrick Born Mon, 09/28/2009 - 16:13
  • Cisco Employee,
Hi Luca,
SIP-B is only for use with Sylantro 3rd-party call control, so it should not be used unless Sylantro is deployed. Given that you mentioned a SPA9000, I can't think of a reason why SIP-B would need to be enabled on the phones.
The best way to configure the system is to use the SPA9000 Setup Wizard:
https://www.myciscocommunity.com/docs/DOC-8126;jsessionid=0550DB915977AB094992AACF4802A3CE.node0
Patrick
lbuongio Wed, 09/30/2009 - 02:14
Hello Patrick!
Many thanks for your answer.
I made that question because I noticed that I was not able to call a hunt-group using an analog phone
connected to one of the FXS ports. I mean the call is ok, all the phones are ringing but as soon as one
IP-phone picks up the hook the line is busy.
At the beginning I was thinking about SIP-B not being available on the FXS but a very simple test showed
me that hunt groups are not using SIP-B at all.
At the moment I am fairly sure that the reason why this is not working is because the calling phone should
support dual-lines .... but I am not completely sure about this.
Can anybody eventually confirm me that, when the hunt group is called internally, the calling phone should
support dual-lines?
Thanks again,
Luca
Patrick Born Thu, 10/01/2009 - 16:06
  • Cisco Employee,
Hi Luca,
A single line analog phone connected to the SPA9000's FXS port can call hunt groups without issue.
Make sure that you use the SPA9000 setup wizard to configure the SPA9000 voice system and all phones. There is a lot of difficult syntax that leads to typing errors which can cause all types of interesting scenarios.
Patrick
