Disk Abnormal Errors
Sep 28th, 2009
Hi ,
I have a CORE WAE 574 that is reporting the following error:
Software RAID devices:
DEVICE NAME TYPE STATUS PHYSICAL DEVICES AND STATUS
/dev/md0 RAID-1 ONE OR MORE DRIVES ABNORMAL disk00/00[GOOD]
/dev/md1 RAID-1 ONE OR MORE DRIVES ABNORMAL disk00/01[GOOD]
/dev/md2 RAID-1 ONE OR MORE DRIVES ABNORMAL disk00/02[GOOD]
/dev/md3 RAID-1 ONE OR MORE DRIVES ABNORMAL disk00/03[GOOD]
/dev/md4 RAID-1 ONE OR MORE DRIVES ABNORMAL disk00/04[GOOD]
/dev/md5 RAID-1 ONE OR MORE DRIVES ABNORMAL disk00/05[GOOD]
Can someone please offer some advice on how to resolve this.
Daniel Laden Mon, 09/28/2009 - 17:00
  • Cisco Employee,
Disk01 is bad or does not exist. If you have a single disk 574, I believe this is normal as the software will install with the expectation of two disks.
HTH,
Dan Laden
antonios@za.ibm.com Tue, 09/29/2009 - 05:55
Hi ,
Thanks for your reply.
I have a 500Gb drive installed into the drive bay and do not see the disk lights flashing.
How do I verify that the installed disks are all functional ?
