Pick up parked call from SCCP controlled FXS port
Sep 28th, 2009
All,
I have several FXS ports with analog cordless phones attached to them being controlled by SCCP. The phones work fine and are able to make and receive phone calls, but I can't seem to get the FACs to work properly. Whenever I try to use an FAC to pickup a call, I get a fast busy signal as soon as I press the prefix digit. For example, I have the prefix digit set to #. As soon as I press # I get a rapid busy signal.
Here are the relevant portions of my configuration:
stcapp ccm-group 1
stcapp
stcapp feature access-code
prefix #
voice-port 0/0/3
timeouts ringing infinity
station-id name Cordless 1
station-id number 121
caller-id enable
voice-port 0/2/0
station-id name Cordless 2
station-id number 122
caller-id enable
sccp local Loopback0
sccp ccm 192.168.100.1 identifier 1 version 4.1
sccp
dial-peer voice 10 pots
service stcapp
port 0/0/3
dial-peer voice 11 pots
service stcapp
port 0/2/0
telephony-service
fac standard
ephone-dn  16  dual-line
number 121 no-reg primary
pickup-group 1
label Cordless - x121
description Cordless
ephone-dn  17  dual-line
number 122 no-reg primary
pickup-group 1
label Cordless - x122
ephone  1
device-security-mode none
mac-address 4C4C.81BC.0003
max-calls-per-button 2
type anl
button  1:16
ephone  8
mac-address 4C4C.81BC.0100
type anl
button  1:17
Here are some relevant show commands...
show stcapp device summary:
Total Devices:           2
Total Calls in Progress: 0
Total Call Legs in Use:  0
Port       Device          Device   Call          Dev     Directory   Dev
Identifier Name            State    State         Type    Number      Cntl
0/0/3      AN24C4C81BC0003 IS       IDLE           ALG     121        CME
0/2/0      AN24C4C81BC0100 IS       IDLE           ALG     122        CME
show stcapp feature codes:
    malicious call ID (MCID) ***
    prefix #
    call forward all #1
    call forward cancel #2
    pickup local group #3
    pickup different group #4
    pickup direct #6
    meetme-conference #5
  stcapp feature speed-dial disabled
stcapp call-control mode is standard mode
show sccp:
SCCP Admin State: UP
Gateway Local Interface: Loopback0
        IPv4 Address: 192.168.200.1
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.100.1, Port Number: 2000
                Priority: N/A, Version: 4.1, Identifier: 1
                Trustpoint: N/A
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 192.168.100.1, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 10
Reported Max Streams: 14, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
Alg_Phone Oper State: ACTIVE - Cause Code: NONE
TCP Link Status: CONNECTED, Device Name: AN24C4C81BC0100
Reported Max Streams: 1, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 20
Supported Codec: g711alaw, Maximum Packetization Period: 20
Supported Codec: g729ar8, Maximum Packetization Period: 220
Supported Codec: g729br8, Maximum Packetization Period: 220
Supported Codec: g729r8, Maximum Packetization Period: 220
TCP Link Status: CONNECTED, Device Name: AN24C4C81BC0003
show ephone anl:
ephone-1[8] Mac:4C4C.81BC.0003 TCP socket:[1] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 9/9 max_streams=1
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:6
IP:192.168.200.1 39427 SCCP Gateway (AN)  keepalive 63 max_line 1 available_line 1
port 0/0/3
button 1: dn 16 number 121 CH1   IDLE         CH2   IDLE         shared with monitor-ring
Preferred Codec: g711ulaw
ephone-8[9] Mac:4C4C.81BC.0100 TCP socket:[9] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 9/9 max_streams=1
IP:192.168.200.1 12639 SCCP Gateway (AN)  keepalive 227 max_line 1 available_line 1
port 0/2/0
button 1: dn 17 number 122 CH1   IDLE         CH2   IDLE         shared with monitor-ring
I am running 7.1.1ea software-wise.
This is driving me up the wall; please help!
--Mike
Marcos Hernandez Mon, 09/28/2009 - 12:35
  • Blue, 1500 points or more
Configure a FAC custom code under telephony-service and that should do the trick:
UC520(config)#telephony-service
UC520(config-telephony)#no fac standard
fac standard has been disabled!
UC520(config-telephony)#fac custom pickup local #3
fac pickup local code has been configurated to #3!
Marcos
mega-byte Mon, 09/28/2009 - 12:51
Marcos,
Thanks for the prompt reply. This solution has already been put into active use. I will have to get back on-site to test.
I don't understand the relationship between the "stcapp feature access-code" and the "fac custom" command. Judging by the output of "show stcapp feature codes" I have already configured a local pickup FAC. Do the settings defined under "stcapp feature access-code" have no effect?
--Mike
Marcos Hernandez Mon, 09/28/2009 - 13:13
I guarantee that the commands I geve you will work in your case. The thing is that you are confusing the access code that is used to pickup a call ringing on an FXS port (method recommended by me) vs. picking up a call FROM the analog port (which makes use of the stcapp commands). Makes sense?
Marcos
mega-byte Mon, 09/28/2009 - 14:51
Marcos,
I understand the difference now that you have explained it, but I _am_ trying to pick up a call in one of the parking slots _from_ the analog port.
Here is the scenario:
A call comes in on an FXO port.
The FXO port is PLAR'ed to a voice hunt-group containing 1 or more IP phones.
One of the IP phones in the voice hunt-group answers the call and then parks the call. Lets say for instance the call is parked at 175.
I am trying to get an analog phone attached to an SCCP controlled FXS to pick up the call parked at 175.
This is what I cannot get to work.
Call parking is configured properly because parking and park retrieval work fine from IP phones.
I have the command "no service directed-pickup" defined under the "telephony-service" section because that setting most closely emulates my customer's pickup needs.
I'm wondering if that has something to do with it.
--Mike
Marcos Hernandez Mon, 09/28/2009 - 14:54
The same pickup code that you use from the IP phones should work for the analog SCCP phone. Just use the FAC configuration under telephony service as indicated earlier.
Marcos
Steven Smith Mon, 09/28/2009 - 15:16
  • Gold, 750 points or more
If you are using call park, I don't believe you need any of this.  You should just to be able to dial the number the call was parked at.
mega-byte Mon, 09/28/2009 - 15:24
Steven,
I agree and that was my initial thought. When I go off-hook on one of those analog devices and dial the number of a parking slot, I just get a rapid busy signal.
I am able to pick parked calls up from the IP phones by just dialing the 3 digit extension of where the call is parked.
--Mike
Steven Smith Mon, 09/28/2009 - 15:41
I am seeing some erratic behavior on my system on this as well.  Dialing the park number is the correct procedure.  Would you open a TAC case so that this gets tracked accordingly.
Steven DiStefano Wed, 08/04/2010 - 05:47
I think its time to pick this up and run with it again.
I have noticed a difference in ** code behavior, and see that BOTH FAC Standard and STCAPP are enabled on my UC540.
As a result, there are 4 codes which overlap and cause the features (like the one named by Megabyte) to work differently....
Working with Engineering now, to see if we can just disable STCAPP on FXS and still have FAC
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:"MS Mincho";}
UC_540#show stcapp feature codes
    prefix **
    call forward all **1
    call forward cancel **2
    pickup local group **3
    pickup different group **4
    meetme-conference **5
    pickup direct **6
    forward-to-voicemail **7
    cancel call waiting **8
But we want more, so we (CCA) also enables FAC standard, which I see are configured as standard in Telephony-Service.  I get all the red ones but the bold conflict and don’t work.
UC540#sh telephony-service fac
  telephony-service fac standard
    callfwd all **1
    callfwd cancel **2
    pickup local **3
    pickup group **4
    pickup direct **5
    park **6
    dnd **7
    redial **8
    voicemail **9
    ephone-hunt join *3
    ephone-hunt cancel #3
    ephone-hunt hlog *4
    ephone-hunt hlog-phone *5
    trnsfvm *6
    dpark-retrieval *0
    cancel call waiting *1
Steven DiStefano Thu, 08/05/2010 - 12:29
Taking STCAPP off the FXS eliminats the overlap and gives you all the FAC codes.  As follows
UC_540(config)#no stcapp feature access-code
  Feature access-code disabled
