[diskWatcher] CRITICAL: Almost out of space on file system /opt.
I'm getting the following error on my LMS 3.0 Master system. This is a Unic system running on Solaris 10.
I've removed some log files from /var/adm/CSCOpx/log but none of them were very large. I opened the diskWatcher.log file and noticed it was pointing to /opt/CSCOpx/databases. There are some large files under the subfolders in the above directory. /rmeng in particular has SyslogFirst.db, SyslogSecond.db and SyslogThird.db. All of which are well over a Gig in size.
Do you have any recommendations on how to clean up the /var partition?
Joe Clarke Mon, 09/28/2009 - 11:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You will need to contact TAC to get the DBSpaceReclaimer.class tool. This tool can then safely drop the syslog data spaces, freeing up the disk space.
