Re: DSP (PVDM-32) Hardware conference bridge setup on Cisco 2800 gateway
Sep 28th, 2009
I have a cisco 2821 gateway and I would like to setup hardware based conference usig PVDM-32 card installed. What steps do I need to configure on the gateway to get this working?
Nicholas Matthews Mon, 09/28/2009 - 12:02
Briefly, it is this:
voice-card 0
dspf pro 1 conference
ass app sccp
max sessions <1-4>
no shut
sccp local
sccp ccm 1 id 1 version
sccp ccm group 1
ccm 1 priority 1
associate pro 1 register NAMEOFDEVICE
That should get you going.
Nicholas Matthews Wed, 09/30/2009 - 05:36
That command is for something slightly different - dspfarm is the command for using the DSPs for media resources.
m-laing Wed, 09/30/2009 - 10:45
When I try to setup the dspf profile I am not able to set the number of sessions. Is there a command I need to enter to use the pvdm-32 card for conference?
How do I view the dsp cards installed on the router?
Jaime Valencia Wed, 09/30/2009 - 11:15
If you get <0-0> that means you don't have enough resources, CFB demands (at least, depending on codec config and sessions) a WHOLE dsp to work.
A) Add more DSPs
B) Decrease the voice termination channels until you have 16 channels left for CFB. Obviously this means less calls.
Do a sh diag to find out what's onboard
if this helps, please rate
Hythim Ali El Hadad Thu, 10/01/2009 - 07:08
Yes you may have an E1 or FXOs that eat your DSPs
unplug them and check
shutting them down won't affect
